Up Topic Welding Industry / Technical Discussions / hardfacing
- - By zambrota (**) Date 02-28-2011 21:47
Is there anybody there with experience using Lincore 36LS self shielded fluxcore wire? When I put 1st hardfacing layer on E71T-1 underlayer, I’m getting “wormholes” porosity. But on second & third layer no problems at all. All time I used same parameters: voltage, stickout, etc. Cleanliness is not an issue. Any idea, what’s the problem?
Thanks
Parent - - By uphill (***) Date 03-01-2011 00:26
Seen wormholes caused by magnetic polarity in the material. Thinking that the first pass may alter the field.
Parent - - By zambrota (**) Date 03-01-2011 07:49
Thanks uphill,
Any idea what would be the cure for that?
Parent - By uphill (***) Date 03-02-2011 22:14
You might give a stringer bead of build up rod a try . Sometimes it disrupts the field. Machining can be partly to blame.
- - By 803056 (*****) Date 03-01-2011 15:36
Are you welding over materials removed from service or is this brand new steel?
Parent - By zambrota (**) Date 03-01-2011 21:48
Al,
It is the refurbishment on material removed from service. Hardworking area was machined off prior to repair work.
