Look at Balence control settings.
The AC balence performs and is measured a bit differently on a Dynasty when compared to a transformer type power supply.
A transformer machine set to max penetration (10 on a 1-10 control knob) will be producing 68% DCEN
Your inverter based Dynasty will provide a real time digital readout up to 99% DCEN.
Transformer set to 7 of 10 on balence puts out about 55% DCEN...
Try backing down to between 60 and 65 on your balence and see if you don't find better etching, no porosity and better wetting at the toes.
First thing last... Check your fittings shield gas fittings :) .
