So I purchased a CV adapter for a 64 SA-200 after getting it installed and running it everything works. When I put it on stick weld it welds but my cables remote doesnt work. I can adjust it on the front panel and it works that way but not at the remote. Remote worked fine before adapter install. Does anyone else have this same set up or know what the problem could be?
