HEY GUYS, BACK WITH SOME PICS
RECAP:
MY PROBLEM IS WITH 2 7018 PLATES REQUIRED. THESE ARE SET WELD PARAMETERS SO DONT JUST TELL ME TO CHANGE THEM. THE PLATES ARE 3/8" 60 DEGREE V GROOVES WITH 3/32" ROOT FACE. ROD IS 3/32" 7018 THAT MUST BE RUN ON AC.
MY PROBLEM IS THE POROSITY STEMMING FROM THE AC CURRENT. IT SHOWS UP AT RANDOM TIMES, UNPREDICTABLY. I CAN RUN SEVERAL RODS CLEAN AND THEN HAVE ONE WITH A BELT OF POROSITY THROUGH MOST OF IT. THE 3G PLATE HAS A ROOT GAP OF 1/8" AT THE START, 5/32" AT THE FINISH. IF YOU LOOK AT THE PICTURES IN THE PAGE I'M GOING TO LINK TO, THE PICTURES ARE NAMED SO THAT YOU CAN TELL WHAT THEY ARE. THE WELD SEQUENCE WENT LIKE THIS: ONE WELD CLEAN, ONE WELD DIRTY, ONE WELD CLEAN, ONE WELD DIRTY. THIS IS WHEN I BEGAN TAKING PICTURES. YOU CAN SEE THE POROSITY IN THE GROUND OUT AREA FOR THE TIE IN. I RAN ANOTHER ROD AND GROUND IT, AND IT WAS CLEAN AS YOU CAN SEE. THERE IS ALSO A PICTURE OF THE ENTIRE ROOT PASS, A PICTURE OF THE ENTIRE ROOT FACE, AND A PICTURE OF THE ROOT PASS GROUND OUT TO SHOW THE 2 AREAS OF POROSITY. SORRY THE FLASH MADE IT HARD TO SEE.
THERE ARE ALSO PICTURES OF THE 3G CAP PASS, THE 4G CAP PASS, THE 4G ROOT PASS, AND THE 2G TIG ROOT PASS. ANY COMMENTS ON THESE ARE WELCOME, I HAVE NEVER RUN WEAVES BEFORE, ALWAYS STRINGERS, SO THE WEAVES ARENT PRETTY. THE 4G PROBLEM IS WITH ROOT CONCAVITY. ITS BAD ENOUGH TO CAUSE CONCERN, AS YOU CAN SEE IN THE 4G ROOT PICTURE. LIKE I SAID, I HAVE LIMITED TIG, AND MOSTLY ON ALUMINUM, SO THE TIG ROOT ISNT NICE EITHER.
http://thisdysfunctional.org/skillswelding/
ANY COMMENTS ARE APRECIATED-
MATT[/SIZE]
HI,
I REMEMBER SEEING YOUR POST A WHILE BACK BUT I DON'T REMEMBER ALL THE RESPONSES THAT WERE GIVEN SO SOME OF WHAT I GIVE MAY BE A REPEAT.
LETS ELIMINATE THE BASIC STUFF:
1)I AM ASSUMING YOU ARE NOT WELDING IN A WINDY SETTING
2)YOU ARE USING ELECTRODES THAT HAVE BEEN BAKED AND NOT SETTING AROUND FOREVER.
3)ARE YOU USING ELECTRODES DESIGNED FOR AC USE?
4)ARE YOU USING GRINDING WHEELS OR BRUSHES THAT HAVE BEEN USED ON OTHER THINGS SUCH AS OIL, GREASE, PAINT, ETC.?
THAT COULD BE A PROBLEM.
5)IS THERE GRINDING DUST RESIDUE LEFT ON THE WELDMENT AFTER GRINDING?-COULD ALSO BE A PROBLEM.
6)DO YOU HAVE OIL OR GREASE ON YOUR GLOVES THAT COULD GET ON THE ELECTRODE COATING/FLUX?
7)CORRECT ARC LENGTH USED AND NOT EXCESSIVE?
8)MILL SCALE HAS BEEN GROUND OFF OF THE WELD AREA(BEVELED EDGES, TOP OF PLATES, AND UNDERSIDE OF ROOT)?
THESE ARE ONLY SOME OF THE POSSIBILITIES.
GOOD LUCK,
BRIAN MAAS
1]FINE
2]FINE
3]NO... AC/DC ROD IS BEING USED, AS THE CAP PASSES ARE ON DC
4]FINE
5]FINE
6]MARGINAL... SOME CUTTING OIL ON MY GLOVES, BUT I HAVE A NEW PAIR TO USE.
7]FINE
8] THE UNDERSIDE OF THE ROOT HAS NOT BEEN SANDED OFF FOR TIME REASONS, EXCEPT FOR THE TIG PLATES. I'LL TRY SANDING THE START/STOP TABS AND THE ROOT EDGES AND SEE IF IT HELPS AT ALL.
MATT
Just a guess but is the table you are working on nice and clean?
Bill
I don't think your parameters are permenent i think they are suppose to be a ballpark figure for u to use to start out with. Are you sure porosity is in the root or where is it. It is most common in the root and rarely found in fill passes unless u r using bad practise. U need to eliminate that right off the bat. If u know it is in the root find out where. Run a rod and find out if it runs throughout the bead or if it's just in starts and stops. Restarts on this plate are all the grinding,wich is a whole other ballgame. I grind a runway kind of like how u ground to show us the porosity in that 3g palte i think it was. Then i start down below the runway in some old weld metal for it is to be ground out anyway. DO NOT WELD OR STRIKE AN ARK OUTSIDE THE bevel walls for that fails ya right off the bat. Strike the rod wich can also be a BEEEEEATCH and if it does not strike and sticks u throw that sucka away and get a new one. Strike the rod below the the runway so that by the time you get to the runway the rod is burning good and consistent. If it sticks anywhere in that runway area u must grind all over again for that is where porosity will show up. I've chased my restart back damn near an inch from grinding new runways cause the dam rod would stick right when it started burning through the plate. U just have to laugh and maybe throw a few rods. Also i've used many different rods running this seem and u don't have to use an AC rod. Hell they probably run worse then the regular 7018. The Lincoln Excaliber 7018 is the best rod i've run on this plate. It's the Cadilac of all rods in 7018 open root. Stays lit way better then all the others and lights off quick and easy because of it's grafite tip or something of that sort. Also see if you can get on a machine where u can pulse your AC current. If you have a machine with pulsing capability you can control your AC sign wave and the pnetration will come through pretty easy.pay with the nobs alittle bit and keep that rod choked in the Root opening so you can't see any ark on your side. It doesn't say u can't use a machine with pulse so take advantage of all you've got. Lincoln Square waves are good or Miller dynasty's or something of the sort. There is another guy on here who has done this and will be of some real good help so take advantag of it ask all the question you can! E-mail me if you need more info! Good Luck to ya. R.C.
FIXXXXAH, I have seen this problem before. The biggest problem is a simple one, and that is arc lenght. With a 3/32" 7018 electrode you have to keep an arc lenght of 3/32" or less. If your elctrode angle is wrong this can make the arc lenght too long and you might not notice. If you have run a lot of 6010 or 6011 electrodes you have trained yourself to keep a longer arc lenght and oscillate a lot. Using 7018 requires that you keep oscilllation to a minimum (twice the elcetrode diameter), but many welders can adapt with experience. It also looked like you tried to maintain too large of a puddle on the root pass, and this with a long arc lenght will pull porosity in from the back and well as the front of the weld joint. Your cap pass would fail inspection because, as Kix474 stated, you can not have arc strikes outside the joint. I do not think Pulse welding would help, but only add to your frustration.
I reread your recap and noticed that you have 3/32" root face. E7018 is not a pentration electrode like E6010 or E6011, and that would make the weld joint not compatible with the welding rod. It sounds like the WPS for this test is not very practical. I saw almost no keyhole in the picture of your root pass, and that could only come from not using the correct weld joint with the correct welding electrode. MLM
HEY GUYS-
THANKS ALOT FOR THE INFO, THINGS ARE RUNNING much BETTER AFTER A NEW CAN OF EXCALIBER ROD, AND SOME TECHNIQUE CHANGES. I WILL KEEP POSTED AS TO HOW THINGS ARE GOING-
MATT
