Up Topic Welding Industry / Inspection & Qualification / Question for you electronics guys
- - By dmilesdot (**) Date 03-22-2011 14:39
Some of the new flaw detectors on the market offer a square wave pulser circuit.  What does this do for me, the UT tech? What difference will I see? Will I notice anything? Is this simply a gig to sell new instruments? If it improves the method to the point that I can tell the difference, Im all for it, but if its an improvement within the unit that I wont ever be able to tell is even there, then im less than interested.
d
Parent - - By jwright650 (*****) Date 03-22-2011 15:01
Explaination of square wave from NDT.net
See if this explains it well enough.
Parent - By dmilesdot (**) Date 03-22-2011 16:41
Thanks John, some it I understood and some was way over my head.  What I basically got from the article is that with a squarewave, if I cant adjust the pulse length and the machine decides the pulse length it isnt something that I can select to affect what I see on the screen. So while it may change the dynamics of whats going on, I cant adjust it. Thanks for the article it was a good read.
d
