I just got back from the API-653 course where I was introduced to the 5% rule for tensile test.
Where paragraph (d) says “outside of the weld or weld interface” does that mean 1) right at the weld the 5% applies and, 2) the remainder of the base metal must meet minimum requirements?
QW-153.1 Tensile Strength
In order to pass the tension test, the specimen shall have
a tensile strength that is not less than
(a) the minimum specified tensile strength of the base
metal;
(d) if the specimen breaks in the base metal outside of
the weld or weld interface, the test shall be accepted as
meeting the requirements, provided the strength is not more
than 5% below the minimum specified tensile strength of
the base metal.
Donnie Mann
