Up Topic Welding Industry / Technical Discussions / Plasma cut bolt holes
- - By Skaggydog (**) Date 03-29-2011 15:04
For structurial steel, high strength bolts, to what extent are plasma cut holes now allowed?
Parent - By waccobird (****) Date 03-30-2011 08:39
Skaggydog
Bolt holes shall comply with the provisions of the RCSC Specification for Structural Joints Using ASTM A325 or A490 Bolts, Section 3.3 except that thermally cut holes shall be permitted with a surface roughness profile not exceeding 1,000 in.
(25 m) as defined in ASME B46.1. Gouges shall not exceed a depth of 1/16 in.(2 mm).
Answer
Although previous specifications limited the methods that can be used, the 2005 AISC specification, Section M2.5, allows the use of any hole-making method that results in a surface roughness not exceeding 1,000 microinches. Most methods can be used to achieve this, including punching, drilling, and thermal cutting with flame and plasma equipment.
Charlie Carter, S.E., P.E.
American Institute of Steel Construction
AISC also used to require the approval of the E.O.R. but a couple three years ago they dropped the Engineer of Records need for approval.
The last is what led us to our purchase of a Robotic Plasma Beam Line from Burlington Automation http://www.pythonx.com
Hope this helps
Marshall
Parent - - By TimGary (****) Date 03-30-2011 11:17 Edited 05-17-2011 21:49
In addition to Waccobird's learned response, let me add that a problem with flame or plasma cut holes is accuracy of diameter.
The AISC code only allows bolt holes to be oversized 1/16" above the bolt dia. It's just plain hard to hand cut a hole that accurately.
A method commonly used for compliance is to flame cut the hole a little undersize, and then use a reamer to both smooth the gouges and to finish the correct dia.
Tim
Parent - - By Dualie (***) Date 05-21-2011 04:31
hey wacobird hows that python-X system working out for your company?
Parent - By waccobird (****) Date 05-21-2011 08:33
Dualie
Just fine hardest part is keeping jobs lined up to keep him fed.
Marshall
Parent - - By tekla019 Date 05-17-2011 10:32
To add to Wacobird's learned reply, you can get the actual AISC document here:  http://www.pythonx.com/newslinks/useful_links.html
Parent - By swnorris (****) Date 05-17-2011 16:43
Even though RCSC and AISC allow them, job specs will dictate whether they're acceptable on any given project or not.
