Up Topic American Welding Society Services / Certifications / AWS D1.5 / PQR Qualification Req. / Table 5.1
- - By David J ward Date 04-11-2011 19:32
Looking at AWS D1.5M/D1.5:2010 to see if Table 5.1 can tell me if re-qualification would be required for a change in “Each manufacture’s brand and type of cored electrode”. What is meant by “manufacture’s brand”? I.e. if we change from using Lincoln brand to Esab brand, would that constitute as an essential variable or change that would require a separate PQR/WPS.
Thanks,
  DJW
Parent - - By waccobird (****) Date 04-11-2011 19:56
David J ward
First Welcome to The American Welding Society Online Forum
Have youi looked over the commentary section C5.5.1?
It explains it a bit better.
But yes you will need to requalify switching from esab to lincoln or visa versa.
Good Luck
And again Welcome to The American Welding Society Online Forum
Marshall
Parent - - By CHGuilford (****) Date 04-12-2011 16:13
To add to that - manufacturer's brand names are also essential variables.
As an example: Lincoln Outershield 71M and Lincoln Ultracore 71C are 2 different wires and require separate PQR's, even though they are both classified as E71T-1.
Parent - By jwright650 (*****) Date 04-12-2011 16:32
Good Point Chet.
