Up Topic Welding Industry / ASME Codes / B31.3 surface breaking porosity
- By 46.00 (****) Date 04-14-2011 21:16
Hi!
According to table 341.3.2, note 5, surface porosity is only evaluated for welds equal or less than 5mm nominal thickness. Where, then are limits for welds greater than 5mm (3/16)? or are there none?
Must be a limit on surface breaking pores/porosity for weld greater than 5mm (3/16) in thickness?
edit:This is not high pressure pipe work.
- - By 46.00 (****) Date 04-19-2011 01:19
Anyone?
Parent - - By Shane Feder (****) Date 04-19-2011 06:50
There is no acceptance criteria for wall thicknesses greater than 3/16" (5 mm)
See Interpretation 5-20 (B31-86-045)
Regards,
Shane
Parent - By 46.00 (****) Date 04-19-2011 17:52
Thanks Shane!
Guessed that to be the case!
