Grind a circumferential break line using a diamond wheel on a grinder. Be careful not to score the tube. Make some longitudinal score lines from the edge in toward the break line, then use a pneumatic chipper to clear the concrete from the clean line, and polish with power brushes and flap sanders. The width of the removal line depends on the size of your backing shoe.
