I knew it!
Cactus is keeping the poly-hydroscopic activation system that goes with the Timbrens. Without it you will be forced to use the transporter reduction beam to keep the significant weight increase of the petroleum distillates, and UV inhibitors required to keep the silicone and alcohol based weight defiance system operating properly.
I couldn't resist, the whole vantage versus SAE 300 thing has inspired me to be F.O.S.
(FULL OF S##T).
