Up Topic Welding Industry / Technical Discussions / Spacers for Joint B-U3a-S
- - By Backdoor Man Date 10-29-2002 15:04
Dear fellows: AWS Code indicates for this joint "Spacer = 6 x R" (SAW). Can you clarify what does it mean? Thanks in advance.
Parent - By DGXL (***) Date 11-02-2002 20:13
6 x R = 6 mm spacer thickness, R = root opening dimension (mm)
(e.g.: D1.1:2000, TC-U5a Spacer dimensions are 6 mm by 10 mm if the groove angle is 30 degrees.)
Don't try this with your 2002, they screwed this up and the metric section has a fraction (inches) for this dimension. You have to do the conversions for your $300.
This will probably require the AWS to raise the price again for this publication...
