Dear all,
Please refer to ASME section IX âQW-402.24 Qualification with a cooling medium (water, flowing gas, etc.) on the root side of a test coupon weld that is welded from one side qualifies all thicknesses of base metal with cooling medium down to the thickness of the test coupon at the root or 1â2 in. (13 mm), whichever is less.â
Can you please tell me where or what is "the thickness of the test coupon at the root" in above sentence?
Thanks.
