By Shane Feder
Date 05-05-2011 02:19
Edited 05-05-2011 02:22
Hi guys,
I think the answer is shown in Reply 2 (1) , (2) & (3)
B31.3 Interpretations No. 1
Interpretation: 1-62
Subject: 336.5, Types and Extent of Required Examinations
1-62
Date Issued:
File:
June 9,1982
1578
Question (2): Please refer to the progressive examination delineated in 336.5. For 5% radiography, at
the point of original examination, a 5% sampling has been represented (1 out of 20). Should that radiograph
fan to meet specification, two additional examinations are required, which represents a 15% (3 out of 20)
sampling.
(0) If any of the second group faUs to meet Code, is it mandatory, as the Code implies, that
further examinations are required? Is the alternative available whereby all welds of that given group of 20
may be totally repaired without subsequent radiographs?
(b) If any of the third group of radiographed welds fails to meet Code, does one progress to a
fourth group?
Reply (2):
(0) No to both questions. The following options are available.
(1) Replace all items in the group. Examinations performed on items which are subsequently
replaced may not be counted as contributing toward the required percent random examination.
(2) Continue progressive examination, repair and reradiograph all defective welds until they
are acceptable. Only the first weld in the group may be counted toward the required percent.
(3) Repair and radiograph all welds in the group until all are acceptable. Only the first weld
(b) No. At this point in the progression. aU welds in the group (20) shall be replaced or repaired
and radiographed until acceptable.
Regards,
Shane
