Up Topic American Welding Society Services / Certifications / 6GR on Box Tubing
- - By BrennanD Date 05-06-2011 16:18
I'm looking for guidance on 6GR qualification of box tubing in accordance with Fig. 4.28 of D1.1. Considering that the internal and external corner radii of box sections are usually dependent upon the wall thickness, would you still be required to have the minimum difference in wall thickness of 3/16" between the two test tubes as shown in the figure? I realize that there is a note that says that the tube with the restrictor plate shall be of the same size as the tube without, but it doesn't say that the wall thickness can be the same, the 3/16" dimension is still present with no notes attached to it.
Thanks!
Parent - - By BankerQC (*) Date 09-12-2012 16:50
nkn;/'  ,l/l'/mj
Parent - - By jwright650 (*****) Date 09-12-2012 17:07
Wake up Bob, you fell on your keyboard.....J/K buddy....I have no clue what you just typed?
Parent - - By welderbrent (*****) Date 09-12-2012 19:34
You didn't recognize that John??
He's using a year old thread to transmitt highly classified, top secret, double agent messages... :lol:
Have a Great Day,  Brent
Parent - - By jwright650 (*****) Date 09-12-2012 20:33
I'm thinking he was reading the thread, and somewhere all the way, dropped something on his keyboard that pressed several keys then slid across the "enter" key. <--purely speculation based upon what was typed vs observing the neighboring keys on the keyboard. :surprised:
Parent - By 46.00 (****) Date 09-14-2012 22:22
wow! I thought it was spy speak!
