Seems you could make your own visual aids, a piece of clean plate, perhaps knock off the mill scale so it is shiny metal. Then maybe another piece on top tack welded to the clean one. Then make 3 of them, run several passes of stick, mig and tig on each one. With this you could show the precise control of the tig by running a tiny fillet or something and do fillets on the mig/stick with similar size rod, say, 3/32 for all processes. Just a thought, good luck.
Shawn
