Up Topic Welding Industry / Technical Discussions / Tig welding alum?
- - By dumfarmer Date 11-05-2002 14:46
Recently bought a Lincoln Tig 250/250 welder. Seems to tig weld steel ok. Tried welding 1/16 alum, probably 6061. AC, high freq, air cooled torch, 1/16 electrode ( recommended by supplier) apx 20 cu. ft. argon. The arc seems to wander around blackening the surface until it falls thru without ever forming a puddle. I cleaned the metal using a stainless brush and balled the electrode. I Don,t have much tig experience. Whats wrong? Thanks, Larry
Parent - By Niekie3 (***) Date 11-12-2002 18:54
The fact that the surface becomes black sounds to me like you are getting some contamination into your gas. There are so many possible origins for the contamination that I am not going to even try to mention them all. (Not only will I forget half, but it will take me all night.)
The fact that the material just suddenly "falls through" is a typical problem when welding light gauge Al. Al alloys are typically designed to have a relatively small melting range. (As this decreases the cracking tendency.) This means that when it starts to melt, it very suddenly becomes fluid. In addition, Al has a very high thermal conductivity. This means that you need to add a great deal of energy befor the melting starts. The third complicating effect is the oxide layer. This oxide layer melts at an extremely high temperature. Much higher than the melting temperatue of the Al. This means that if you should have excessive oxide on the surface, you will not see anything happening untill all the base metal beneath the oxide is moulten, at which stage the "falling through" bit happens. When one combines these three factors, you end up with a material that is extremely difficult to control during welding.
You state that you are cleaning the Al, and also using HF AC current to weld it. This should help with the oxide removal, but again, there are many possible problems that can creep in here.
Personally I believe that you are being somewhat optimistic in believing that you can weld such a thin Al. Possibly somebody with a great deal of experience welding Al can do this using a pulsing power source. Even then, s/he will have trouble.
Niekie Jooste
Parent - By Kix474 (*) Date 11-13-2002 08:24
probably suckin air somwhere either in the torch or in a line somewhere. Steel will still weld ok with it suckin alittle bit of air. Try some stainless if you don't get any color you are suckin air. Also i had a problem one time welding with a brand spankin new machine on aluminum. They said it was the brand new lines haveing something in them that needed to be ran out and would clear up after awhile. The aluminum welded like Sh!t and after a few hours it never cleared up and the contest was over so i never really new what was wrong. I still think it sounds like u suckin air somwhere..
