Up Topic American Welding Society Services / Technical Standards & Publications / CVN requirement per AWS D1.1
- - By Yang Changwang Date 05-25-2011 13:29
Per D1.1 Section 4.33.1 "The CVN test requirement shall apply only when specified in the contract documents"
Now, I have a project. And there is no special requirement mentioned in our technical contract or design drawings. So I think only bend and tensile test should be done and no CVN test needed.
But my collegue thought the base material used in qualification test which has CVN requirement, so we should add CVN test.
I am puzzled because there are no related words describe "if base material has CVN requirement, so dose the welding Joint" in AWS D1.1
Can someone tell me whether my understanding is right or my collegue's.
PS:The material used in our project is Q345B, a material which is similar to ASTM A572 Gr50, but with property"20℃,34J".
Parent - By 803056 (*****) Date 05-31-2011 14:15
Per D1.1, notch toughness requirements only come into play when the Engineer specifies CVN testing is a project requirement. The Engineer must specify the minimum toughness and the test temperature.
