Test light or ohm meter. If gages or switches ground it out and no power to the fuel solenoid it won't run that is what shuts it off. Check connections, switches, wires, gages and for power when on in run position at the fuel shut off solenoid and make sure you have full 12V to 14.5V there.
http://billswelderrepair.com/schematics.html
