Up Topic Welding Industry / General Welding Discussion / Looking for a company that can bend up to 3" sched 40 SS
- - By Kix (****) Date 06-07-2011 13:09
Does anyone know of anywhere where you can get this done?  I saw an add in the latest AWS journal for a place that does monsterous roll forming on plate and pipe, but I left the mag at home and I can't remember there name.
Thanks,
Kix
Parent - - By lucky1 (**) Date 06-07-2011 13:13
send me the specks i have a bender.
Parent - - By Kix (****) Date 06-08-2011 18:43
Is it a mandrel bender that can do multiple bends on one spool?
Parent - By lucky1 (**) Date 06-09-2011 13:18
no not a mandrel bender lust a regular bailigh but we have 3"dies
Parent - - By js55 (*****) Date 06-07-2011 14:41
You shouldn't have that much trouble finding someone. 3" is not big. 72" is big. :smile:
It has to be bent to the same radius as a long radius 3" sch 40 90's and 45".  I have found a couple places that said they could bend my angles, but couldn't do mutiple bends on the same spool.  We haven't seen an actual built unit yet to see how it's been done in the past so we don't know what our options can be.  Some of the spools have multiple bends in them according to the drawings like they were mandrel bent.  The place I've found said that they would put waves on the inside bend radius and reduce the wall thickness on the outside of the bend by up to .156.
Parent - By js55 (*****) Date 06-09-2011 12:33
A 1 1/2 D bend is pretty tight by bend practice because it isn't done like fittings. You will get intrados thickening and extrados thinning ALWAYS. When thickening on the intrados gives way (not a technical term) you get buckling. Refer to PFI for tolerances. However, the thinning tolerance will be based upon allowable design thickness. An experienced bender will have bend tables that can tell him whether or not you can maintain the extrados thickness you need.
Parent - By petty4345 (**) Date 06-07-2011 14:53
I think this is who you are thinking about.
Hodgson Custom Rolling Inc.
Parent - - By Cumminsguy71 (*****) Date 06-07-2011 16:18 Edited 06-07-2011 16:20
There's a place in Chicago called Chicago Metal Rolled Products. Its www.cmrp.com. Hodgson Custom Rolling is 800-263-2547 they are up in Niagera Falls, Canada. Guy I've talked to at Chicago was Gary Sheridan. Seemed like good prices especially with shipping etc.
Parent - By Kix (****) Date 06-08-2011 18:44
Do they do mandrel bent pipe?
Parent - - By Kix (****) Date 06-08-2011 18:56
I checked out that place in Chi town and their website looks pretty good.  I fwd the we id over to out purchasing dept to get in rouch with them.
Thanks!!
Parent - - By Milton Gravitt (***) Date 06-08-2011 22:45
Kix try this www.hcrsteel.com it is Hodgson Custom Rolling maybe this will help.
   M.G.
Parent - - By Kix (****) Date 06-09-2011 15:28
Thanks!  I'll check out there site.
Kix
Parent - - By dmilesdot (**) Date 06-14-2011 17:09
There is another place in Duluth Mn. called Bend Tec their number is 218-722-0205. Very knowledgable people about bending all sizes of pipe.
d
Parent - By Kix (****) Date 06-16-2011 16:09
Thanks for the info!  I'll check them out to.
