Yeah, it is pretty amazing stuff. I know many glass walls supported by it, and I've heard it's used on some aircraft exteriors. The 3M document "Design Guide for Architectural Metal Panels" includes a picture of the Gehry Concert Hall. I guess it's used on that building's skin (not much else I can think of that would work there).
In those applications, it's "give" allows it to hold together flexing structures, without overstressing the corners.
http://multimedia.3m.com/mws/mediawebserver?mwsId=SSSSSu7zK1fslxtUn8_e48txev7qe17zHvTSevTSeSSSSSS--&fn=ArchitecturalPanelbro.pdfIt shows a lot of aluminum being held this way.
You won't be able to glue or tape 2 foot long 1"x3" legs to a 14" square piece of aluminum safely, BUT if those legs could be bolted (or welded) to a different aluminum plate (maybe 12" square so it hides under the part being displayed), you could probably tape the two flat surfaces together successfully and hide the bolts that way. You just need sufficient surface to bond the plates, and a way to compress the tape with the recommended 15 psi of compression to set the initial bond.
The spec sheet I'm looking at, shows a bond strength (which takes 72 hours to be fully reached) of between 55 and 160 PSI (depending on the exact tape) in tension, on aluminum. About 1/3 less in dynamic shear, and between 12 and 25 lbs per lineal inch of tape (depending on which one), to pull up at 90 degrees off of stainless.
See:
http://www.markingsystems.com/uploads/media/3M_4926_foam.pdfThe catch, is that these materials are prone to "creep" in static shear. From that same document:
Use the right amount of tape: Because 3M™ VHB™ Tapes are viscoelastic by nature their strength and stiffness is a
function of the rate at which they are stressed. They behave stronger with relatively faster rate of stress load (dynamic
stresses) and will tend to show creep behavior with stress load acting over a long period of time (static stresses). As a
general rule, for static loads, approximately four square inches of tape should be used for each pound of weight to be
supported in order to prevent excessive creep.
That may be your undoing if you don't plan this well. So, do you know the angle of the mounting? Multiply the sine of the angle from horizontal by the weight of the piece, to calculate the shear force, and that will let you know how much tape you'll need to make this work.
