I use .030 MIG tips for the gas orfice in forge burners. I seem to remember measuring the hole at .037".
I have a 110 volt "MIG" welder that wasn't feeding reliably. Turns out it had a .030 tip on it, but I was trying to put .035" self shielded wire through it. When it worked , the diameter must have been on the lower side of the tolerance, when it jammed, the higher.
