Hello all,
I work in a shop that uses ASME Section IX WPSs for all of our work. I'm going to develop some procedures that cover us for structural welding (mostly hangers and stands) under D1.1.
The requirements for SMAW are fairly clear in D1.1, but my question has to do with GMAW, specifically GMAW-P. How does D1.1 address "mixing and matching" of welding processes? I understand that if I want to use GMAW-S I need one procedure for that. What do I need to do to use GMAW-S and GMAW-P in the same weld? For pipe welding we typically put in a GMAW-S root and GMAW-P balance. I'm leaning toward submitting a PQR using both processes (short-circuit and pulsed), but what happens when I want to make a fillet weld with GMAW-P only? I've found information on mixing prequalified processes, but not non-prequalified processes.
Any suggestions?
