Up Topic Welding Industry / Welding Fundamentals / How to calculate Bevel and Included of Single V joint
- - By Nalla (***) Date 06-19-2011 21:00
Dear Friends
Pipe Single-V joint preparations
Mat 5mm thk. x 18" dia or variuos dia )
WPS call for Bevel Angle 25 ~ 30 deg with root face of 1mm.
I want to make template for fitters , so that without gauges they should be able to follow WPS.
Appreciate quick response
Thanks.
Parent - - By DaveBoyer (*****) Date 06-20-2011 01:40
Lay it out on a piece of sheet metal, cut it out and file to the layout. Put a line 5mm down to indicate the inner wall, and another line 4mm down to show the edge of the bevel.
Parent - By Shane Feder (****) Date 06-20-2011 11:11
Nalla,
As Dave has stated lay it out on some sheetmetal.
I would cut a straight edge with a Vee ( 5 mm high) at 55 degrees included angle (2 x 27.5 degrees) that way you can use it for prepping and also for completed set up of joint. (Just add the root gap)
Bit hard to explain without a diagram - hope you understand what I am trying to say,
Regards,
Shane
