Hi Mike,
With respect to some CMM's, if they have a type of granite such as a "black gabro" as opposed to a "pink or blue Vermont/New Hampshire' type of granite in them that practically doesn't wear at all during the yearly time frame with a fairly good amount of use or not, then the yearly calibration would be necessary according to NIST... The Black gabro would more than likely fall out of tolerance with a fairly good amount of use, inadequate preventive maintenance, and care and would most likely have to be re-cut in order to meet the appropriate grade working surface - overall flatness calibration tolerance ...
Of course, it would also depend on the grade of the granite such as whether or not it is a tool, inspection or lab grade with respect to meeting the
working surface - overall flatness tolerances required in order to be either re-calibrated or reworked such as to meet the listed calibration standard tolerances which is usually to NIST and/or similar standards listed on the calibration sticker or plate.
