Up Topic Welding Industry / Inspection & Qualification / Misc Projects
- - By Jozef Date 07-05-2011 14:21
I work at a Fabrication shop in Milwaukee. We are looking for someone to come in part time (after they are done fishing or hunting of course) and inspect weld quality on our completed projects on an as needed basis. If anyone is interested please let me know.
Parent - - By Joseph P. Kane (****) Date 07-05-2011 16:57
Jozef
What code or specification allows completed weld inspection only?   Isn't before - during - and after inspection required?  Which ever CWI does this should be sure he/she is not violating the Code of Ethics.
Joe Kane
Parent - - By qcrobert (***) Date 07-05-2011 20:11
I've performed inspection of completed weldments in the past.
Usually the contract calls for VT on completed welds along with dimensional checks and occassionally to witness a pressure test and/or vacuum test of a completed weldment.
Parent - By 99205 (***) Date 07-05-2011 22:23
You can PM me with all the pertinent info if you like.
Parent - By joe pirie (***) Date 07-06-2011 03:08
ICC building code all single pass fillet welds undr 5/16 do not require continual inspection
City of Los ASngeles Building code. welding don in the shop of an approved fabricator require no outside inspection
