I did however find a section 4.1.2.1 Previous Performance Qualification that states...
"Properly documented evidence of previous performance qualification of welders, welding operators and tack welders may be accepted with the Engineer's approval. The acceptability of performance qualification to other standards is the Engineer's responsibility, to be exercised based upon the specific structure, or service conditions, or both. Welders and welding operators qualified by standard test to AWS B2.1, Standard for Welding Procedure and Performance Qualification, may, in this manner, be accepted for use in this code."
We hired an outside contractor (an AISC erector) to help us with some welding man power shortages and this is one of thier welders in question. They (the outside contractor)accepted his previous cert. without realizing it was an ASME cert. form. He (the welder in question) came to them from Southern Air (a mechanical contractor here in town). It looked like the same form that I had used to qualify some of this contractor's people in the past and he just missed the last statement on the form that stated the test coupons were prepared, welded, and tested in accordance with the requirements of Section IX of the ASME Boiler and Pressure Vessel Code. I notice the SCWI that evaluated this welder, was the one who gave me my CWI exam several years ago. This cert. is fairly recent (Sept. 16, 2002).
John Wright
