Up Topic Welding Industry / Technical Discussions / B 575 (C276) weld procedure
- - By JMAC Date 07-06-2011 14:37
I have an old weld procedure qualified in accordance with D1.6 using A5.11 (incoweld 686) wire. New job coming up, same base metal (C276), but specs call for ERNiCrMo-4 wire (A5.14). A5.11 and A5.14 have the same F# , F43. Do I have to requalify my procedure? Any help will be welcomed.
Parent - - By js55 (*****) Date 07-06-2011 14:55
Yes you have to requalify because when you go from A5.11 to A5.14 you have changed welding processes.
Also, 5.11 and 5.14 do not have F#'s. F#'s are related to classifications. These are specifications.
Parent - - By JMAC Date 07-06-2011 15:21
Nope same process GMAW. Also table 4.5 in D1.6 gives the AWS Specification number A5.11 and A5.14 the F# 43.
Parent - - By js55 (*****) Date 07-06-2011 16:18
A couple points. If the original procedure utilized A5.11 it wasn't GMAW.
If it was A5.11 it would have been ENiCrMo-4 not ER and it would have been a coated electrode.
By changing from 5.11 to 5.14 you have to change processes. You are going from coated electrode to solid wire.
Parent - - By JMAC Date 07-06-2011 17:17
Thank you js, I think I see my problem now, original procedure dates back to 1996, before my time here, all the parameters on the WPS are written for GMAW, mode of transfer, shielding gas ,etc. I am thinking that the specification listed A5.11 has to be a typo by the original author. Thank you again for your response.
Parent - By js55 (*****) Date 07-06-2011 17:44
JMAC,
I do that kind of thing myself. I use existing procedures as templates with data already on them and then move down the form changing data as required. Occasionally I miss something.
Parent - - By qcrobert (***) Date 07-06-2011 16:25 Edited 07-06-2011 16:27
This may help you find your answer...
Attachment: WeldingTable.1.pdf (118k)
Parent - By 803056 (*****) Date 07-07-2011 17:08
I like it.
