Up Topic Welding Industry / Technical Discussions / how to join steel and Al?
- - By xingchi Date 11-14-2002 12:04
It is all known that steel and Al material are used widely in auto industry. who tell me how to join steel and Al with fusion welding method? It is said that Russian has invent this patent about this process. who know about this patent in detail? thanks ,if you know it,please write to me with this email:wuhq888@sina.com
Parent - By tiweld Date 11-14-2002 13:28
It is probably a solid state welding process that is being used , not a fusion process to join Al to steel.
Several options are used including:
Friction Weld
Explosion Welding
Each method has limitations and not at all like typical fusion welding processes.
Parent - By Niekie3 (***) Date 11-17-2002 20:49
Hi
I have previously joined Al to Cu by first buttering the Cu with a Silver solder brazing alloy. Following this, I welded the Al to the silver solder using an Al filler. Possibly you could try something simmilar, if this is what you had in mind.
If this is the type of joining you had in mind, let me know and I will scratch out the filler and brazing alloy details.
Niekie Jooste
