Up Topic Welding Industry / General Welding Discussion / Glass lined Tanks
- - By PipeIt (**) Date 07-12-2011 12:51
We are quoting a job where we have to tie into and existing glass lined tank. My question is there a product or compound of some type that we can apply to restore the integrity of the liner where we cut and weld the new nozzles on?
Parent - By G.S.Crisi (****) Date 07-12-2011 16:26
Get in touch with the two largest glass lined equipment manufacturers in the world and ask them a reccomendation.
www.dedietrich.com
www.pfaudler.com
Parent - - By Len Andersen (***) Date 07-14-2011 18:35
Sir,
     I have worked as a chemical engineer with glass line steel tanks / reactors, have five patents in welding and been a CWI since 1993. There are many systems of that nature none of which are of the original capability on corrosion protection. What you can do to get glass lined capability is put the unit with the nozzle welding done into a furnace re-glass coat it at about half the cost of a new vessel. That is the beginning of a long story! I hope this is helpful.
Sincerely
Len Andersen weld@spemail.org
                 212-839-6599 8-4 New York Time , 4042 FAX , Co-worker 6381 / 914-237-7689 (H) / 914-536-7101 (Mobil)
POB 1529 / NYC 10116-1529 ( $1090 per year Caller Box GPO NYC )
                       www.lenandersen.com
Parent - By PipeIt (**) Date 07-14-2011 20:17
Thanks all for the replies, I excluded this service from my quote in the interest of time and it will fall under the owners scope.
Regards,
PI
