By Tommyjoking
Date 07-13-2011 02:53
Edited 07-13-2011 02:58
I think optrel had a hood (maybe still do) that had built in fans for fogging and air movement...do not think it ever took off. If you really need it Optrel and others make positive airflow "hoods" that use pumped in air (like from a compressor or A/C system)....it is basically a big shroud of material you wear with a flex hose hooked to it. Caterpillar issues these rigs in it's factories, they are expensive.
You could check some of the higher end sporting goods stores/catalogs....I remember seeing a weird backpack thing a few years back that you filled with ice water and it pumped the water thru velcro bands you could strap on your neck/head whatever...like a cheap weird version of a cool suit.
