MDK,
“The parts are in the as welded condition.”
So, your area of interest is the weld bead and adjacent area no?
Then, be specific!
5.1 Prior to magnetic particle examination, the surface to be examined and adjacent area
within 1 inch of either side of the weld bead and, within one inch of the end of the plate(s) shall be dry and free of any dirt, grease, welding flux, spatter, oil or other extraneous matter that would interfere with the examination.
Now, the poor Level I trainee knows EXACTLY what areas to prep!
“Why do you ask if it’s porous?”
Because you lumped too many ‘surfaces’ together … A sponge can be dry within 1 inch of “the surface”.
“I think im ok with lumping visual requirements with MT requirements because MT is an enhanced visual inspection. “
No, you are
NOT ok lumping them together … If it doesn’t pass “VISUAL” it shouldn’t leave the bench or weld area until it meets YOUR minimum criteria!
VT, MT, PT, RT, UT, etc, they ARE separate!
Remember that the welder is the FIRST inspector and should have “Visual Inspection Criteria” before he or she puts down the first bead.
THEN, use “enhanced visual inspection” to ascertain if there is something the eye doesn’t or can’t see.
Sorry if I seem a bit critical but, as I said …
There is nothing that I like better in this world than to be in the middle of no-where with the specs in one hand and my gear in the other, looking at a part or parts that should have been re-worked or rejected before I even got there!!
Cheers,
jb
