You are correct, and I am going to write a SDR for the change from MT to PT, but I thought I would check to see if it is even possible before stating that it is not in my SDR.
Half the lugs are A36 to A36, and the other half are A36 to 304L, but we'd like use only one process to keep from setting up twice on each unit.
