Up Topic Welding Industry / Inspection & Qualification / SA-105 FORGED INTO SA-350
- - By Mikeqc1 (****) Date 08-09-2011 20:21
If SA-105 material  is forged into a product that requires SA-350 lf2 c1 material do any of you all know what more is required by SA-350.
Code references on the subject would be great.
i know that charpy testing is done for 350 but without going over the specs line for line im not sure what else i should be aware of.
i have the 105 mtr then it was forged into an SA-350 piece with a new set of MTRs and test results.
Is there any one who is familiar with sa 388 ? i like to pick your brain on the  acceptance criteria and recording/reporting requirments.
MDK
Parent - By js55 (*****) Date 08-15-2011 12:34
Mike,
I'm not really sure what the problem is. Since its SA its Section IIA. And if you have a copy of such, SA-105, you have SA-350 and SA-388. Recording/reporting would be page 1. Testing and criteria would of course be in the body of the specification.
