Up Topic Welding Industry / Technical Discussions / Oxygen Manifold and Piping
- - By rickandcheryl (*) Date 08-19-2011 19:00
What is the correct material for a new Oxygen manifold and connecting piping? Can it be black iron or does it have to be copper??
Parent - By TimGary (****) Date 08-19-2011 20:20
It really depends on the intended service for the oxygen, but I would say welded stainless steel with minimal threaded connections.
Black Iron and Copper will contaminate the oxygen.
Parent - By 99205 (***) Date 08-19-2011 20:27 Edited 08-22-2011 02:36
http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=STANDARDS&p_id=9854
OSHA
• Part Number:  1910
• Part Title:  Occupational Safety and Health Standards
• Subpart:  Q
• Subpart Title:  Welding, Cutting, and Brazing
• Standard Number:  1910.253
• Title:  Oxygen-fuel gas welding and cutting.
1910.253(d)(1)(i)(A)
Piping and fittings shall comply with section 2, Industrial Gas and Air Piping Systems, of the American National Standard Code for Pressure Piping ANSI B31.1-1967, which is incorporated by reference as specified in Sec. 1910.6, insofar as it does not conflict with paragraph (d)(1)(i)(A)(1) and (d)(1)(i)(A)(2) of this section:
1910.253(d)(1)(i)(A)(1)
Pipe shall be at least Schedule 40 and fittings shall be at least standard weight in sizes up to and including 6-inch nominal.
1910.253(d)(1)(i)(A)(2)
Copper tubing shall be Types K or L in accordance with the Standard Specification for Seamless Copper Water Tube, ASTM B88-66a, which is incorporated by reference as specified in Sec. 1910.6.
1910.253(d)(1)(i)(B)
Piping shall be steel, wrought iron, brass or copper pipe, or seamless copper, brass or stainless steel tubing, except as provided in paragraph (d)(1)(ii) and (d)(1)(iii) of this section.
Parent - By DaveBoyer (*****) Date 08-20-2011 03:49
In a medical building the company that My Dad worked for built, the Oxy lines were copper soldered with a silver bearing soft solder, Staybrite or similar.
At the auto frame plant I worked at, I think they were threaded steel pipe.
Parent - By 357max (***) Date 08-22-2011 13:32
If you mean oxygen and acetylene manifold. DO NOT USE COPPER with acetylene!!! It is a fantastic means to remodel a building.So if the building is too crowded, go for it.
- - By jbndt (**) Date 08-20-2011 18:43
Just be CAREFUL who cuts and threads the pipe …
We all know how oxygen and petroleum products  react!  :eek:
There is also a “special” thread sealant made specifically for “oxygen rich” applications.
Cheers,
jb
Parent - By fschweighardt (***) Date 08-21-2011 18:55
- - By rickandcheryl (*) Date 08-22-2011 14:50
Thanks guys, looks like we will go with seamless type K copper, silver soldered. Fire dept OKed threaded black iron, but plumbing contractor used wrong sealant twice, so we decided on silver soldered copper. Don't trust threaded joints that have been put together and taken apart numerous times with the same fittings.
Parent - By fschweighardt (***) Date 08-23-2011 11:48
back purging the braze joints with N2 is a good idea
