James,
What process(s) have you tried? Would a soldered joint work? I would think that an electric soldering gun of sufficient wattage should do the trick.
Anyway, I have to agree with Giovanni about my knowledge of welding such thin materials, particularly copper which conducts heat so well.
I too, hope that someone will be able to answer your question, so I too, can learn alittle more myself.
John Wright
