Up Topic Welding Industry / Processes / Brazing Nickel and Iron Alloys Containing Al and Ti
- - By Matt Pohlman (*) Date 09-11-2011 14:49
Many brazing specifications require nickel plating of the braze joint surfaces when the combined aluminum and titanium content is over about 0.6 wt %.  Does anyone know where that limit came from?  Was there test data to support it? Should it apply only when filler is placed outside the joint and required to flow in or should it also apply when the filler is preplaced in the joint?
Parent - By ravi theCobra (**) Date 01-11-2012 00:37
Hi there Matt
I would as a FIRST STEP  look through all of the WBS -27 's  (I think) to see where plating is first referenced -
