No, full radiography is the same as 100% radiography. If you're speaking of a pressure vessel built to ASME VIII, the joint efficiency will be 1 (one) or 100%. Giovanni S. Crisi Sao Paulo - Brazil
Also a pressure vessel built to ASME VIII Div 1 may have a JE of 85% (see UW-12) in which case you use Spot RT which in this case is not to be construed as 85% RT.
