Up Topic American Welding Society Services / Certifications / D17.1 question
- - By BryantB (*) Date 09-28-2011 03:53
Hello,
    I've been reviewing AWS D17.1 to gear up in order to draft a new procedure qualification record for a welder, and can't seem to find any specifics on GTAW filler material size.  If I don't list the size of the filler material on the PQR, will it be acceptable?  If I do list the filler material size on the PQR, am I bound by that size?
Thanks
Bryant B.
Parent - - By Ringo (***) Date 09-28-2011 10:44
Size of the filler metal doesn't matter,only the thickness of the material being qualified.
Parent - - By BryantB (*) Date 09-28-2011 12:59
Is there any specific information that clearly states that?  For instance if the weld program were to be audited how would I explain that filler material size does not matter?
Thanks
Bryant b
Parent - - By Ringo (***) Date 09-28-2011 13:05
No,5.4.2 just says filler metal used,as in type,no size requirement.
Parent - - By BryantB (*) Date 09-28-2011 14:37
5.4.2 in d17.1? There is no 5.4.2 in d17.1.
Maybe im in the wrong?
Parent - - By Ringo (***) Date 09-28-2011 15:06
I'm lookin' right at it. page 22.D17.1 2nd edition.
Parent - By BryantB (*) Date 09-28-2011 15:36
I have the aws d17.1:2001 publication its not here.
Parent - - By BryantB (*) Date 09-28-2011 15:37
Does it say word for word that there is no size requirment for filler material?
Thanks
Parent - By Ringo (***) Date 09-28-2011 16:47
I have the latest and greatest,the 2010 edition,but no,it just says filler metal used as an essential variable.I've never listed size on a PQR.
- By BryantB (*) Date 09-28-2011 17:18
Yeah I wish I had the newer version. Seems like they are being vauge intentionally.  Elsewhere in d17.1 it mentions that u should use filler metal in production welds of similar composition to the filler used in qualification  with no reference to size. I just wish that there was an easier way to clearly state that I don't have to list the filler material size.
Thanks
Bryant b.
