Hello justahand, set your meter to DC voltage and touch/attach +/red lead of the meter to the + terminal and the -/black lead to the - terminal while the machine is not welding. If it is an engine drive, force it to kick to high idle before testing the voltage. The reading that you get will be the OCV for the machine. Hope that helps. Good luck and best regards, Allan
