Up Topic Welding Industry / General Welding Discussion / Welding Duplex 2205 with GTAW multipass with 2%N/98%Ar
- - By Eutectic (**) Date 10-10-2011 07:39
I need confirmation of successful fabrication with Duplex (2205) with GTAW multipass process utilizing 2%N/98%Ar as the shielding and backing gas. I would greatly appreciate any feedback.
Hanre
Parent - By Lawrence (*****) Date 10-10-2011 08:29
Parent - - By ssbn727 (*****) Date 10-11-2011 03:05 Edited 10-11-2011 05:56
Here's some more confirmation for you... This one is identical to another post...So I'll just give you the link instead.:wink::cool:
http://www.aws.org/cgi-bin/mwf/topic_show.pl?tid=29000
I'm giving you the link because our moderator would rather have it this way instead of cluttering the sections with identical posts.
Edit: This one is from Acelor Mittal... Refer to page 7:
http://www.industeel.info/datasheets/pdf/ur2205Mo.pdf
This one I almost forgot to post:
http://www.kcicms.com/pdf/factfiles/duplex/ssw0912_duplex_kotecki.pdf?resourceId=110
Anywho, Enjoy the reading:eek::yell::roll::lol::wink::cool:
Parent - By Eutectic (**) Date 10-11-2011 07:34
Henry,
Again, thanks for your help, it is much appreciated.
Cheers.
HF
Parent - - By Jim Hughes (***) Date 10-15-2011 13:17
Eutectic,
our company just finshed a scrubber project where I had to qualify WPS's to exactly what you mention in your post. The only difference is we also had to qualify the procedures to ASTM A923 A,B, and C. Used Pinnicle wire and worked very well. Welded very easy. Heat input had to be kept low. Could not tell any difference between 2%N/98% Ar. and 100% Ar. The only issue we had was making sure we had a process to segregate the two gases.
Hope that helped.
Jim
Parent - By Eutectic (**) Date 10-19-2011 14:17
Jim,
Thanks, that is exactly what i am looking for. Much appreciated.
Cheers
Hanre
