Robert,
Al, or even Joe Kane, could probably do a much better job of answering this but:
It is not that they may not have the knowledge and/or ability to properly do so, it is because of the stipulations from QC1 and B5.1 from the Code of Ethics as well as the job responsibilities of the person who has attained a CAWI and not a CWI or SCWI. They are very limited what they can do during their 'apprenticeship' time of being supervised to attain the required additional training in order to qualify for re-exam to attain the CWI level. They must be within visual and audible distance to the CWI/SCWI and their duties are very restricted by their status, not because of their knowledge or ability. Anyone can witness a welder take an exam, except a CAWI due to it not being in his job specifications in B5.1 and if he did so he then violates the Code of Ethics. Now, he can watch, alongside a CWI and ask questions, observe, and learn. Even be a helping hand to the CWI. But can't do it himself. And can't sign off on it. Anyone can write a WPS (though the SCWI is the only one of the three who is required to have that ability as a Certified Inspector), a company rep, the welder, a CWI, a SCWI, BUT NOT THE CAWI. Not within his job description due to the restrictions of his learning/apprenticeship status and the Code of Ethics.
This has been well covered and even ARGUED before. There is much disagreement on the total scope of application. But the intent seems to be that the level of CAWI really limits what one is able to do. It has been stated you are better off to not have it and just retake the entire exam when ready because of the limitations incurred with it's acceptance.
I hope I have expressed this properly and helped you understand Al's statement. If I made any mistakes, I'm sure I will hear about it.
Have a Great Day, Brent
Hey Robert
AWS B5.1
Table 1
Procedure qualifications (4) (5) (6) (7)
http://www.aws.org/certification/docs/b5.1-2003-errata.pdfAWS QC1 4.4
http://www.aws.org/certification/docs/qc1-07.pdf4.4 The CAWI shall be able to perform inspections,
under the direct supervision of a SCWI or CWI within
visible and audible range, and as defined for the AWI as
in AWS B5.1, Specification for the Qualification of
Welding Inspectors.
It is the SCWI or CWI, however,
who has responsibility for certifying that welded assemblies
conform to workmanship and acceptance criteria.
Emphasis mine
