Material A606 11ga, Joint design is a 1" weld every 4", then to seal the seam they go back over with a silicon based sealer and seal the non welded areas. I was looking at mig brazing for the lowered heat input would allow to weld entire length no stops, and seal as well. Testing a mig silicon bronze wire this next week pulse settings with 100% Argon.
