Up Topic Welding Industry / Technical Discussions / Plastic Welder
- - By WeldingChat.com (**) Date 11-03-2011 23:56
Plastic Welder wanted in Tempe Arizona for Foresight Technologies
details: http://www.weldingjobs.com/welder179.html
Parent - - By OBEWAN (***) Date 11-04-2011 00:02
I bet that will be a hard job to fill.
I seem to remember seeing an article several years back about plastic pipe welding in Europe.  They were welding heavy wall, with a beveled joint and plastic filler. It was an automatic process too.
I think the Europeans are ahead on this one...
Parent - By DaveBoyer (*****) Date 11-04-2011 03:40
The job the OP is offering is manual hot air/plastic filler work. As they said, it is different from other welding. There are plastic fab shops, much like a steel fab shop but working with plastic. one of My friends is VP of the one in Our town, it is an interesting shop.
Some years back My cousin was fabricating custom thermoplastic water & waste tanks for boats, that is the only time I have done any of this type of welding. He wanted Me to take over for Him in Annapolis, but having just been diagnosed with cancer, I could not.
Parent - - By G.S.Crisi (****) Date 11-04-2011 18:36
No, Steve. Heavy wall plastic pipe welding is carried out in automatic machines according to the method called "hot plate plastic welding".
The pipe ends are square and no filler is used.
The pipe ends are put into contact one on each side of a hot plate until a few millimeters of the end is molten. Then the pipes are taken away from the plate, the plate is removed and the pipes ends are pushed one against the other until they solidify, thus making up a welded joint. All the operation is automatic.
The whole natural gas distribution piping net of Sao Paulo city (18 million inhabitants) was constructed in this way.
Enter www.omicronitaly.com and select the English language.
Once in there, click on Products.
Once in there, click on Butt fusion technologies.
Once in there, click on Butt fusion machines.
More than once I've suggested on this Forum that AWS should have a Committee on plastic welding, but I wasn't never heard.
Parent - - By OBEWAN (***) Date 11-04-2011 19:25
It was so long ago that I do not remember the details.  Sorry I did not mean to mislead.
Thank you for posting up the current methods.
Steve
Parent - By OBEWAN (***) Date 11-05-2011 12:58
Here is an article on plastic welding.
They show a procedure for pipe with bevel and plastic filler.  I don't think it is for high pressure or oil work though.
http://www.kamweld.com/Plastic_Welding_Using_Kamweld_s_Durable_Welders.pdf
Parent - - By unclematt (***) Date 11-13-2011 19:02
Hello;
I have done this kind of welding in the U.S. using a manual machine. We used the hot plate as you mentioned and a manual buggy with clamps to hold the pipe. After heating the ends and removing the hot plate, we used a lever to slide one to pipe the other stationary pipe and applied pressure. As the pressure was applied, the hot material, in my case poly, would roll out forming a bead of material. It looked similar to a weld bead on steel pipe. We ran about 5,000' of 4" this way without leaks. Was an interesting job. Wish there was an automated rig on that job.
Have a good day;
Matt
Parent - - By 803056 (*****) Date 11-14-2011 21:47
Just as a side note on the subject of welding plastic, I started welding plastic when I was a youngster many years ago.
I discovered I could use my wood burning tool (soldering iron) to fuse my models together instead of using glue. Of course this didn't work very well with small parts, but it did work for long seams like joining the deck to the hull of the ship and it work very nicely with the tank hulls. I used the styrene runners as welding "rod". The major advantage was that the model didn't fall apart in water as did the "glued" models. It was imparative that the model ships stayed intact on their last voyage across the pond, decks set ablaze and firecracks waiting to be lit. Such a glorious end to many a model ship.
Parent - By DaveBoyer (*****) Date 11-15-2011 03:20
The hot air welder is only slightly more sophisticated. Heat is controlled so that the parent material and filler are not quite melted, but soft enough to flow. With the speed tips, the filler is squezed ino place as You move along the seam, really pretty simple once You get the heat and speed figured out.
