Up Topic Welding Industry / General Welding Discussion / Sarlun, Sargol
- - By Jack8rkin (*) Date 11-04-2011 06:42
Hello everybody!
Just wanted to ask you if the Sargol and Sarlun terms are widely used and commonly known in the US. In my previous thread I asked about a lip weld.
The Sargol and Sarlun turned out to be just what I was asking about (or similar to that). It turned out that "the lip weld" is out of the AWS terminology. But the description of the Sargol and Sarlun facings use the term "lip":
"The Sargol and Sarlun facings, which have lips for seal welding, are used frequently for severe service conditions."
So, plase, tell me if the terms Sargol and Sarlun are common and widely acceptable.
Thank you.
Parent - - By qcrobert (***) Date 11-04-2011 13:52
New to me but I'm always learning, thanks for the info!
QCRobert
Parent - By Jack8rkin (*) Date 11-04-2011 16:38
Thank you for your opinion!
- - By Jack8rkin (*) Date 11-04-2011 06:45
This is what our guys call a "lip weld":
(Well, I'm from Russia.)
Parent - - By Tyrone (***) Date 11-04-2011 10:55
Hey Jack,
Here's an interesting article on gate valves.
http://www.novabizz.com/Valve/Manual_Gate_Valves.htm
"The "Sargol" type (or combination joint), which is a flange joint with a seal weld", this is what you call a "lip weld".
Someone else would have to comment on the Sargal-Sarlun terms.  (I've never heard them before, but I'm not in the valve field).
Tyronw
Parent - - By Jack8rkin (*) Date 11-04-2011 16:37
Thank you for help!
Parent - - By 803056 (*****) Date 11-05-2011 13:09
I believe AWS would simply refer to the "lip weld" as an edge weld. It is one of the five joint types (butt, corner, T, lap, and edge joint) listed in AWS A3.0.
Parent - By Jack8rkin (*) Date 11-07-2011 15:08
Oh. yeah! That's what I was told here -- "edge weld".
Thanks for info!
