Hi khodabandeh
Ok thanks, now I understand the "root repair" test requirement. This then means that you will need 8 repair PQR tests to be performed. (This is a very stringent requirement, and I believe it is way over the top, but if the client is happy to pay for it, then give him what he wants!)
Regarding the rest of your question, I believe you are asking me if you must perform the same tests on each of the repair coupons as that performed on the original PQR coupon. (Tell me if I have mis-interpreted this.)
The short answer is that seeing as this repair testing requirement is not a code requirement, but a client specification requirement, this answer should be in the client specification. (If it is not, submit a technical query to the client asking for clarification.) My experience (and this may be different for your spec, so check it!) is that normally the same testing is required for the repair coupons as for the original PQR, with slight modifications such as positions for hardness scans or impact test notches. The exception being that for the surface repair coupon, normally only hardness testing is required.
As a general rule, the repair coupons will be made on the same size of coupon that was used for qualifying the original weld PQR.
Hope this helps.
Niekie
If your doing a repair of a repair on duplex, depending upon the grade, you probably have nothing left but a paper weight anyhow. Too much time at sensitive temps. I would not be surprised if the qualification for repairs involved more than the usual Section IX type mechanicals because this won't reveal the manner in which the material is destroyed.
