ASTM A27 is a cast steel. The chemistry is not controlled to ensure good weldability. It is not prequalified per AWS.
I would recommend you obtain a sample for chemical analysis to determine the chemistry and calculate the minimum preheat using AWS D1.1 Annex I as a guideline. Consider the joint to be highly restrained and the hydrogen control as an H2 if you are using low hydrogen electrodes out of a fresh can or electrode oven.
Give consideration to the sulfur and phosphorus. Make sure their levels are below 0.04%. Lead, copper, and other LMPC can be a concern as well.
