Up Topic American Welding Society Services / Technical Standards & Publications / D1.1 Power Source (equipment calibrations)
- - By rshanks (**) Date 11-17-2011 16:14
All , can find requirement in D1.5. But not D1.1 seems I foundit before but can't find now??
Parent - By ziggy (**) Date 11-17-2011 17:18
rshanks
clauses 5.11 and 6.2 in d1.1 are probably the closest you'll get regarding equipment maintenance; calibration is quite another subject.
the d1.5 is a bit more wordy in clause 4.31. but that is the bridge code, not building.
you may want to inquire of the welding machine manufacturer as to their specifications for routine maintenance and calibration. "calibration" is an interesting word, especially around welding machines. there is much debate about it. is it "calibration" or "verification"? if the machine cannot be "calibrated" then is the meter that "verifies" the machine output what gets "calibrated"?
before you invest a lot of time and monies, make sure you talk to the machine manufacturer, especially about "calibration"
and if that leaves you with questions, send an inquiry to AWS. maybe we'll get an official interpretation on it in the Journal!
ziggy
