Hello vdao3004, very generally speaking; plate would have the grain running parallel to the long side of most pieces when shipped in master plate sizes. Bar stock is the same, the grain runs parallel to the long length. Otherwise you would need to specify when you have parts made that the grain direction needs to be identified. There are some other ways to tell grain direction, but generally these would require a testing laboratory to determine and might be rather cost prohibitive.
Grain direction for test plates should have the groove oriented crosswise/transverse to the grain direction. Hope that helps a bit. Best regards, Allan
