Up Topic Welding Industry / Technical Discussions / 308 Filler Question
- - By leeritenour24 Date 12-08-2011 16:20
Does anyone know where I can find material properties (tensile, yield, shear) for 308 filler wire? I am a defense contractor and have a caveat, I need to pull this information from a government approved/accepted source. I've searched everywhere with no luck.
Any help at all would be greatly appreciated.
Parent - - By Lawrence (*****) Date 12-08-2011 17:40
http://www.hobartbrothers.com/uploads/pdf/datasheets/308_308HSterlingAP.pdf
Something like this?
Whoever is providing your filler metals should have this information, and as a direct military contractor I would be shocked if they diddn't drop everything they were doing to please you.
Parent - - By leeritenour24 Date 12-08-2011 19:04
This is exactly what I needed, thank you very much for your help.
Parent - By Lawrence (*****) Date 12-08-2011 19:41
Please keep in mind that the data on the Hobart link is specific to the brand listed on the sheet.
It is not generic..
It only applies to that specific product, not to the alloy group in general terms.
Parent - - By qcrobert (***) Date 12-08-2011 20:20
Why am I scared?:eek:
Parent - By Lawrence (*****) Date 12-08-2011 21:24
Eh?
Parent - - By fschweighardt (***) Date 12-09-2011 03:47
Same reason as me:eek:
Parent - By Tommyjoking (****) Date 12-09-2011 05:15
:eek:
Parent - By bozaktwo1 (***) Date 12-08-2011 19:04
http://www.matweb.com/index.aspx
https://assist.daps.dla.mil/quicksearch/
The top one is MATWEB, which is a well-known and often-used tool for process engineers.  The bottom one is assist, which gives you free access to almost any fed/mil spec there is.  Good luck.
